NO direct fit
I 100 agree with BT
Your "mechanic is full of it.
I consider myself a somewhat expert on Alpha 1 shifting.
So,
if it is difficult to go into gear then rpms are too high or possible bad cable adjustment.
If once in gear it pops out then as said clutch dog and/or gear engagement teeth are worn and a new gear set is needed.
If it wont come out of gear, then no interrupter switch or nonfunctional/disconnected switch. Or bad cable adjustment. Switch MUST be working for drive to be shifted OUT of gear (forward or reverse) NOT INTO gear........................
If only stalls while going into reverse then either bad short cable or bad cable adjustment 99% of the time.
Many reasons for a drive not to shift INTO gear,
bad cable (s), Bad cable adjustments on either or both the primary shift cable or the short shift cable. Worn cables with too much slack.
Also any one of the shift linkages in the gimbal housing and the drive it self could be worn, or bent or possibly a missing piece. (small wheel on bell crank) seen it!!
So to simply replace a cable and disconnect the interrupter switch, That "mechanic" should find a different line of work...............Maybe Midas Muffler!!
