daveolejnik
My outdrive on my boat went. I
My outdrive on my boat went. I found a small crack on the lower unit housing. After tearing it apart I found There is a bearing ou on the upper half and the lower end is shot. My question is This is of a 1977 3.7 470. I believe it is a pre alpa outdrive? I can get a mercruiser 165 pre alpa outdrive of of a 1978 boat. Will this bolt up? I also see a few outdrives for the older 140 mercruisers. Are these also the same? The serial # on my outdrive is 4527560.
