pyavenger23
I'm new to this site and boat engine issues, but now that I own this 1977 SeaRay185 with a GM straight 6 cylinder engine, a $1K "deal of the year"...sure could use some help in root causing why the oil pan was holding 1 quart of clean water, and likely more. Over full dip stick reading led to draining the oil pan...only water flowing out so I replugged it. I know it will take X many oil changes and dry cranking cycling to push & purge all the water out, then finally an attempt at starting it up....but what are likely causes of H2O in the oil pan??? This was supposedly "properly winterized" last year. Secondly, any other major concerns to address because of the water in the oil pan???
