Hi,
I have a 1977 Johnson 55 hp I recently purchased to get back in running condition. I replaced the impeller and thermostat (and a lot of other stuff) and it runs good, but I don't have any cooling water exiting the motor above the water line. The two slots at the rear base of the power head have nothing coming out of them while running and water hose hooked up. There is what seems to be a pee hole at the front of the lower unit where it mates to motor that starts flowing as thermostat warms up. Is that all I should see? Warm water is coming out of there and block temp fluctuates between 140 and 170. Is this normal? Just used to seeing water exiting above water line somewhere. Thanks.
