1977 Johnson 15hp No fire
hparker
Was running and just quit, no fire on either cylinder. Checked the coils and they are good. Is the power pack bad?
check all kill switches,,if there working proper,,then i would say considering either coil has no spark...pack would be bad...
Why not test the sensor coil and charge coil first ?? ------------It is likely the pack, but you can test the other items.
easiest is to test the charge coil and sensor coil.-------------Look for a ---------------trouble shooting guide on ----------------cdi electronics----------- Good luck.
