"i have a 1977 johnson 140. mo
"i have a 1977 johnson 140. motor sat winterized for about 3 years until last year when took it out 3-4 times. Motor ran fine except i do not believe it was charging the batteries when in use. What could be causing this issue? I plan on using the boat a lot this year and would like to give the motor a good tuneup. What parts should i replace? I plan on changing the plugs,wires,lower unit oil.I have the service manual and will be doing the work myself(no good ob mechanics in area). How hard is it to do a carb cleaning/rebuild? thanks for the help"
