1977 johnson 115 etl
kegs
ps to my prior hard starting q
ps to my prior hard starting question.
after motor has been sitting fuel and oil are running down the leg.
"fuel should not be coming out
"fuel should not be coming out after engine is off , possibly a stuck float, did you set them all the same.
try this remove airbox cover and look and see if it is blowing out of a particular carb,that may be an indication of something else like reeds,etc
ruling out carbs were done properly."
"pull the breather off,.squeez
"pull the breather off,.squeeze primer bulb,observe inside of carb---fuel running out,...clean/rebuild both using new parts.no leak,..then u r seeing fuel 'condensate'..from the exhaust hsng...if u have liquid gas running down,...the carbs and fuel pump needs to be ck'ed."
