"timing is set as per your pos
"timing is set as per your posts.
new needle and seats and gaskets to carbys.
motor runs very well and idles good around 850 to 900 rpm idle.
need to crank engine for some time before it fires up from cold, less cranking requiried once engine is warm., it does attempt to fire early when cranking but fails to flame up.
eventually starts and idles ok.
is this float level to low or too high causing flooding.?"
