I am trying to set up the timing and sync of the motor.
When I hook up the timing light with #1 cylinder.
I got 4 BTDC for primary pick up. 20 BTDC for max advance. And I initially set the idle at 1 BTDC.
Ok, then I more the timing light with all the other cylinders. And I found out the flash shows all the same position as the #1 cylinder.
What could be the reasons of this problem?
The motor is equipped with a distributor trigger.
Thanks.
Thanks.
