1977 Ford 305351W
stewsbs
Anybody know if this engine ta
Anybody know if this engine takes a clockwise or counterclockwise starter and is it 9 teeth on the gear or 10 and can I use an automotive starter just to get me through Memorial Day and if I can what would that engine have been in I know it was a truck.
"305 is chevy, 351 is ford.
f
for ford check the firing order 1,3,7,2,6,5,4,8.This is for standard rotation"
"He meant 302 I think
On ch
On chevy blocks any matching automotive starter will work so I would assume that any matching ford starter would work also, It just has to match up.
Marine starters are slightly different than automotive as far as coast gard regulations on spark suppression guidelines so be careful.
I personally have purchase rebuilt automotive starters from auto parts stores for chevy marine engines, BUT I know how to make then marine compliant!!! If you can accomplish this then you can do it also if not you are taking full responsibilty if something goes wrong.
Just trying to make you aware and understand the potential consequences."
"Most are standard rotation, U
"Most are standard rotation, Using inboards as an example, if the starter is mounted to the engine then a standard engine takes a standard starter, IF the starter is mounted to the bell housing,than a standard motor uses a reverse rotation starter.
If yours is engine mounted and has the firing order above , you need a standard rotation starter,for the number of teeth count the old one."
Ghost ford starters are the sa
Ghost ford starters are the same as chevys the head is the same just some have smaller/bigger assyembly
