Mark stevens
In 1986, I bought a used runabout 19' boat and rebuilt the outboard engine. It ran strong until 2013 and would not start. I had no spark and replaced both ignition modules in 2013. It then had a strong spark and would fire up for a short time (10 seconds or less) when I sprayed a mixture of oil/gas directly into the 3 two barrel carbs. It's a 2 stroke, that runs on oil/gas mixture.
in 2014, I struggled to find out what the problem was. It seemed to not get gas to the carbs.
so, I replaced the following:
starter motor
both fuel pumps
squeeze bulb
fuel lines
fuel filter
Drained the old gas and replaced it with fresh gas after sucking out the old fuel
all of these are Evinrude factory parts. Why isn't the gas getting to the engine?
is there a filter screen in the carbs? What else can I check? Fuel pressure? The marina nearby is extremely expensive for labor.
Thanks for for any help, Mark
starter motor
both fuel pumps
squeeze bulb
fuel lines
fuel filter
