dominickowalik
Hi everyone, new to the forum. I have a 77 Evinrude 135 that I bought that was sitting for awhile. I checked compression which was 150ish across all 4 (I suspect a rebuild by previous owner for being that high). It was sitting for a while so I cleaned out all the carbs. At idle it is doesn't run right. It is sputtering and when you give it a little throttle it dies. I will attach a video shortly. It did have spark so I'm not sure what is up with it. Could it be a timing issue. it seems to be sneezing and it dies. (Carbs were cleaned out properly with air and were soaked and went through all the small passageways).
