1977 70HP operating Temp
rude70
I am trying to calibrate a sen
I am trying to calibrate a sender unit to an OMC temp guage. The sender unit is mounted to touch the cylinder head. Does anone know the normal operating temperature of a 1977 70HP?
Best to have a clearance of .0
Best to have a clearance of .010 between the sensor and the cylinder head in order to avoid false readings.
I believe the opening temperture of the thermostat is 143°.
"Thanks Joe. I have purchased
"Thanks Joe. I have purchased a new sierra stat that says 143 degrees. However when I tested it in a pot of water, it seemed to open at aroun 160 degrees, unlees my thermostat was wrong"
