1977 6 hp evinrude
jmann
i have been working on this en
i have been working on this engine but can't seem to get it running. started with bad power pack and coils and fuel pump replaced all of these and cleaned the carbs. now have spark and fuel getting to the carb but not to the plugs reeds are free. when i first checked the comp. it was 120/120 after getting fuel and spark still no start checked comp again 85/85 could this be a bad head gasket or sopmething else any thoughts would be appreciated
"<[img]"http://www.marineengin
"Do not enter duplicate posts,
"Do not enter duplicate posts, it only makes for confusion.
The fact that the compression readings are identical might indicate that the head gasket is failing a a area between the two cylinders. It would be a good idea to check that possibility.
Also, did you manually clean the fixed brass high speed jet that's located in the bottom center portion of the float chamber? Fuel must flow thru that jet before it gains access to any other fuel passageway.
Thousands of parts in my remaining stock. Not able to list them all. Let me know what you need and I'll look it up for you. Visit my eBay store at:
"I am having trouble with my 1
"I am having trouble with my 1985,70HP evinrude motor.Never had a problem since it was new.After it sits there 4 or 5 days it will not start.The fuel hose bulb pumps up.I put a new power pack on it.I put a spark tester on plug wire,good spark.I might go back the next day and it starts right up and starts and runs all day after it starts the first time,no problem. then next week, same thing. Any help,I'M stumped"
"[i]"I am having trouble w
""I am having trouble with my 1985,70HP evinrude motor"
<font color=""119911"">This topic is about a 6hp engine. If you have a question to ask start a new discussion, enter something in the subject box that indicates what the question is about and then ask your question</font>"
