1977 55HP Evinrude Water Flow
rhlee222
Hi Everone,
I just purchased an old boat with a 1977 55HP Evinrude. The motor runs but needs carbs rebuilt, rebuild kit on the way.The person I bought this from said he replaced the impeller and lower unit seals. I am trying to find out if water is flowing correctly. I have been reluctant to run it for more than a minute because it doesn't idle. When I put muffs on it and turn on the water, water comes out between the lower and upper unit. I thought this would be sealed. When I started it very little water came out through the prop. I then started it in a tub of water. Water again came out between the lower and upper units. I was expecting water to come out of the vents in the rear, right below the motor. Do I need to let it warm up to observe water flow? Does this motor have a thermostat? If someone can explain to me what I should be looking foe I would greately appreciate it. I also have a repair manual on the way.
Thanks in Advance,
​​​​​​​Rick
