"thanks for the water pump tri
"thanks for the water pump tricks.update on the way it was running,i changed the upper crank seal,spark plugs,rebuilt the fuel pump,still ran the same with the muffs on,so we put it in a barrel of water,WOW what a difference it idles good now responds with the cold start lever and doesn't race out of control,totally different motor.wonder if most of the problem was running it withe muffs on instead of the barrel,did that because pump wasn't pumping anyways now it idles a little low but i think a little adjustment to the linkage to open the throttle blades might be all i need.THANKS FOR ALL THE HELP YOU ALL SURE KNOW YOUR STUFF.i guess i don,t have to pull the plug on the boat in the middle of the lake after all."
