SeaDuctions
I need some help figuring out what is the problem with my 1977 26 ft cabin cruiser with a 10.5 beam. I bought the boat with the 454 mercruiser un repairable. So the Marina I got my boat at, said they could put a 350 mercruiser 1979 in and I would be happy with it.
No need in getting into the opinion of this marina but things did not work out.
The 350 engine runs great at a idle and rpm is @1,000 set by the marina. Oh yeah it is a reverse rotation engine with a velvet borge warner V-drive 1to1 ratio straight drive shaft.
It works fine til you push the throttle into the 4 barrel and then it bogs down and looses speed. I have no information about the boat's performance prior to buying it. The engine is rebuilt from the machine shop which the marina did and they installed the engine and did the wiring.
what is new?
crank, cam, piston heads exhaust manifolds and risers, carburetor.
What is rebuilt
alternator, starter
what I know about the boat since I have got it running.
It has done 24 mph at about 4,000 rpm according to lowrance gen3 with a little room to push it more but at that time was unsure of boat so did not push more. The new carburetor was back firing alot so the marina adjusted it and and finally replaced it with another new one.
The engine ran good for a very short time then I'd found a water leak in the muffles and had to replace them. Turns out the muffles had no insides and fell apart when removed.
Since then......no speed can only get about 8 mph and engine had a valve tapping. Marina told me that putting on the new mufflers put back pressure on engine speed. I took the muffles off and put straight hose on and that did not improve the performance.
Long story short the Marina rebuilt the whole engine.
I took it out and got up to 19mph at 4,000rpm and that was full throttle with the 4 barrel kicking in but did notice a flat spot but passed threw it.
now less than 10 hours on the rebuilt engine, it will not let me pass into the secondary on the carburetor just bogs down.
Does anybody have any ideal what the problem is? I was really expecting the boat to do better than 24mph but now it will only do 9 to 13mph.
I have put another used carburetor and it did the same thing, so I do not think it is the carb. I feel something has deteriorated but not sure what.
I am down to the plugs, advance electric timing since it has no points or the transmission is binding up but it seems to run fine til I try to open the secondary .
Does anybody know how fast the 350 should be able to go?
The boat weighs about 7,500 and is a V-hull fiberglass.
what is new?
What is rebuilt
alternator, starter
