nicklanigan
Hi all,
I've got the following symptoms:
Motor starts and runs well from cold, no issues whatsoever.
After working the motor hard - towing kids on biscuits/wakeboarding etc, if I turn the motor off, I end up with a problem when I restart it.
The motor will restart no problem at all, and will go into gear and power the boat at low RPM - under about 2000.
As soon as I try and accelerate the boat beyond about 2000 rpm, the motor simply dies. There is no sputter/cough/anything - it's like someone has simply turned the motor off.
If I accelerate up to close to this rpm point, then ease off throttle to lower the rpm again, the motor will continue running at low rpm/idle no problem at all.
After a few minutes, this behavior clears itself, and I'm able to accelerate again past 2000 rpm. Occasionally, it sounds as if one or more cylinders suddenly decides to start firing.
I'm at a loss to what the problem is.
Taking major systems in turn:
Fuel - symptom exists even if I have someone squeezing the fuel bulb when the problem occurs. Fuel bulb behaves in a completely normal manner. Carbs have been cleaned. I don't see any way that fuel can be my issue given the motor runs great at all engine speeds, other than after a warm restart for a few minutes. Carb bowls have been emptied to check for water - none present, and a decent fuel filter/separator is fitted.
Compression - all healthy, around 115 psi. Motor has recently been rebuilt - this problem existed both before and after the rebuild.
Ignition - Because of a variety of other wear and tear issues, my motor has a pretty new stator/timer base/coils/spark leads and power pack. All components test fine according the cdi test procedures, but I'm doing the tests at home with the gear case etc in a bucket, not when the problem is occurring. The stator and timer base have been examined carefully and tested with an ohm meter a number of times, so I believe they are both in good condition.
I'm down to being suspicious of one of 3 things:
- Poor engine grounding. I went through and replaced the various grounding cables, as all were in poor condition. I guess I'm suspicious of a wire/connection failing or increasing in resistance when hot, then coming right when cool again. I have yet to take the boat out with the replaced ground connections.
- Spark plugs - these are a couple of seasons old, but look fine. I don't see how bad plugs could cause my issue, unless they had some kind of insulation fault that becomes apparent when hot.
- Power pack. Am I unlucky enough to have a couple of power packs fail in relative close spacing? I have definitely had a heat related power pack issue previously, but in that case, a single cylinder was dropped when the engine got hot. This was resolved with a new power pack.
Do my 3 suspicions sound logical? Or is there something else I should be looking at?
Nick.
Nick.
