nicklanigan
Hi all.
Pulled off the gearcase the other day to replace the impeller - first time I've personally done it.
Just a question on the water tube grommets involved - according the parts diagrams there are two water tube grommets - one is located in water pump body, part #314008 from the following link:
http://www.marineengine.com/parts/j...5TXL77S&manufacturer=Johnson§ion=Gearcase
There is also another grommet which seems to fit on the end of the water pipe which is listed as part #305145 from the following link:
http://www.marineengine.com/parts/j...&manufacturer=Johnson§ion=Exhaust+Housing
Mine did not have the second grommet present (on the end of the tube).
Just want to confirm the parts diagrams are correct, and I should have two grommets? Presumably if so, someone has done a lazy repair job at some point.
Much appreciated as always, and apologies if the links don't work, first time I've tried in this editor.
Nick.
Nick.
