1977 1150 115HP SURGINGALL SPEED CARBS HAVE TO BE SYNCED UP
rushman
"I HAVE A 1977 1150 115HP OUTB
"I HAVE A 1977 1150 115HP OUTBOARD NEVER DID THIS BEFORE I DID THE CARBS( REBUILD THEM ) COULD I HAVE DONE SOMETHING WRONG. DO THEY HAVE TO BE SYNCED UP ALL THREE AND I USED THE SAME PAPER GASKETS I KNOW I SHOULD HAVE GOTTEN NEW AND SCRAPED THE OLD BUT...... http://s293.photobucket.com/albums/mm67/prairiedog700/?action=view&current=06280 81349.flv
HAVE A LISTEN TO THIS MIDE YOU ITS ON WATER LIKE GLASS THANK YOU ANTHONY CHRIS WHAT DO YOU THINK"
I MAY NOT HAVE MADE TIGHT THE
I MAY NOT HAVE MADE TIGHT THE CARB BOLTS WHAT IS THE SPEC FOR TIGHTING THOSE THINGS WITH A TORQ WRENCH
Spray carb cleaner on the base
Spray carb cleaner on the base gasket to see if it leaks. The sync should not get too messed up.
