Rocketman14
I found a 1976 55 hp Sea Horse motor for $350,and it looks like a good motor. I know, I broke the golden rule buying a motor and not hearing it run but for $350 I took the gamble, plus it had all the controls to go with it.
I hand spun the flywheel and the motor felt good and tight and there was no slack in the rods that I could feel. Each compression stroke felt fairly even as far as I could tell. I also shifted it from forward, to nuetral and into reverse and spun the flywheel and verified that the prop turned in forward and reverse.
So by this weekend I will have it on the boat and will begin rebuilding the carburators, new water pump, and basically do all the maintenance one would normally do on a motor that has been sitting for 5+ years.
I plan on doing a compression check and would like to know what the minimum compression value would be. I know, I should have did that before buying the motor but I was out of town when I ran into the deal and didn't have my tools with me.
Also how good are these motors? I can find no history on their reliability but I do remember seeing them on a ton of boats in the late 70's on.
A friend told me that they were a bulletproof motor but that is all I know.
