I have a 1976 Mercury 200 20 hp outboard with electric start (serial # 4354881). I have had problems with the wiring since I bought it (it had been spliced in many places, had taps for fish finders, radios, etc., and had some corrosion), and have a question about the wiring harness. I have cut the wires in the external harness about three feet from the motor, as there were several splices and bad insulation closer to the controls in several places. I find continuity between nearly all the wires in the harness when it is unplugged from the outboard and sitting on my bench. If I put it on a battery, I get 12 volts from the red and black, but a few volts across red and yellow, orange, etc. Same with black across the other wires. The 7 wires look good where I cut them, and the plug looks good. Does this mean something failed inside the plug and the only repair is a new harness? Could it have corroded or melted inside to leak voltage from the hot wire to other wires?
