Got a boat and an old 1976 electric start Merc 110 9.8 hp. I changed the lower oil and the spark plugs and to my awesome surprise it started right up when I hooked it up to my battery.
I have a few questions about it though. When it starts up water comes out the pee hole within a few seconds. It runs out the hole for about 5-10 seconds pretty freely but then stops. Then another couple minutes it does the same. I'm afraid to keep running it to see if itll keep doing it or if itll continuously run. Is this normal or do I probably need to replace or rebuilt the water pump? Along with this, does this motor have a thermostat or is it supposed to pee water the whole time?
Next question is that there is a little threaded hole right by the water pick up under the fin. Just wondering if something is supposed to be threaded in this hole? I've attached a pic.
And last is simple. What ignition is on the 76? The thunderbolt?
Thanks for any help!
