dudemccrackin
I have a 1976 Johnson Outboard motor Model 35EL76G. I bought this on a 15 foot aluminum boat almost a year ago and it started and it ran fine. I rerigged the entire boat with new accessories but did nothing to the motor, motor wiring or anything to do with the motor. Every so often I would turn the motor over just to make sure it was ok but I never actually cranked the motor because I didn't have it in the water and I didn't have any fuel.
So today I was going to take the boat out for the first time and connected the fuel line with plenty of fuel and pumped the primer bulb. It turned over perfectly but didn't start so I thought it hadn't received fuel yet and pumped the primer bulb a few more times. I turned the key and the motor turned over but didn't fire up so I stopped and went to my neighbors house to get some starter spray and when I got back I turned the key and NOTHING happened. I haven't used the spray yet because now it's not even turning over.
I have disconnected the kill switch, fully charged the battery and still nothing. I used jumper cables to bypass the solinoid (spelling?) and it would slowly turn over like the battery was weak. I changed to the new dual marine battery that is fully charged and it kept doing the same thing!
I'm confused as hell, not to mention frustrated!!! Why would it turn over fine and then just stop trying to turn over at all? I know NOTHING about motors and need suggestions,answers or help of any kind! I would also like to know what the fuel/oil mixture should be. I was told by the guy at Gander Mountain that it was 16:1 so that is what I mixed but the should not be causing this problem if it's the incorrect ratio, in my opinion!
Please give me answers asap! I have spent more money on all the reerigging that I did for the boat, motor and trailer combined and need to start scouting some Crappie holes for clients I have lined up to help pay for this boat!!! Thanks in advance, Tim Kindrick
