racerone I got the correct flywheel key today. I decided before going to the trouble of removing the head i would go ahead and put the correct key in there. I was amazed to find that even with the correct torque the one I had put in there had sheared. So i got my valve grinding paste out and put generous amounts on the tapers of the shaft and flywheel. I think I understand now, if there are imperfections, scratches and what not on the tapers, I am not getting full contact from inside tapers of flywheel to outer tapers of shaft. So there is very little to grab on to, so to speak. Then all the force of cranking the engine is transferred to the key instead. Now the should I just continue to lap by hand or let the starter do the work? If by hand how long do you think would be sufficient?
