Purchased 1976 F-30 Trojan Express FB cruiser with single chrysler 440 engine. Engine ran smoothly on all 8 started easily after a couple hours idling got water in oil. Took engine down pressure tested heads machine shop says no cracks in heads not warped. Installed new head gaskets head bolts, etc confident that job was done right. There was evidence that head gaskets replaced, had not sealed. Top of pistons all uniform black no evidence of water getting in cylinders from manifolds no evidence seen of a cracked cylinder wall. Reassembled, ran a couple hours at idle more water getting in oil now. I replaced the oil cooler when we did the heads. Engine runs smoothly on all eight, starts with no problem no evidence of hydrostatic lock but getting water in oil. People telling me block is cracked below piston ring travel area but I have trouble beliving that a crack would not travel all the way up cylinder wall. Does anybody know anything that might cause oil in water other than a crack in the block. Engine is raw water cooled not fresh.
Also, can this boat reach planing speed if I repower with a chrysler 318, if so, what trans. ratio, what diameter and pitch prop. Are motor mounts in same exact location as the 440. Would very much appreciate anyones expertise thank you !!! Also looking for good condition fresh water cooled chrysler 440 or 318 if I can use it in this boat to buy. Thanks again.
