D
don bell
Guest
I have a 76 Evinrude 115hp wi
I have a 76 Evinrude 115hp with a broke ring on cylinder 1. How can I change only this one pistons rings? Can I just take off only the head or do I also have to take off the pan then remove the connecting rod and push the piston up and change? I need to do a quick cheap fix. Does the connecting rod have to be attached exactly as it was taken off? I was told there is a little play and it has to be aligned perfect. Is this correct? Any ideas of a quick cheap fix.
