1976 55hp evinrude
terryjbarr
need to know how to run and ho
need to know how to run and hook up the gas lines i am only getting gas to one carb and they are both very clean i can spray gas in either one and the motor cranks but someone took off gas lines
"fuel line goes from fuel pump
"fuel line goes from fuel pump to a "Tee" fitting, then from the tee fitting to each carburetor."
"Okay, on that model, the top
"Okay, on that model, the top carburetor has a fuel inlet fitting pointing straight down. The line from the fuel pump attaches to that fitting.
THere is another smaller fitting pointing straight out sideways on the top carburetor. A fuel line attaches to that fitting and leads to a identical fitting on the bottom carburetor."
