foodwatch2003
"After having my 1976 Chrysler
"After having my 1976 Chrysler 360 rebuilt, the mechanic went belly up and lost the distributor gear for the engine. I thought I ordered the correct one a few years back, but now that I am reassembling the engine, I find that the new Mallory distributor does not quite engage the slot in the drive gear when it fits flush with the engine block. This is a CW rotation engine (viewed from water pump end). The gear turns CW as it should. I see two different part numbers for normal and reverse rotation. The other engine(CCW) has a shroud around the base of the distributor to keep the gear in place and it fits fine with the same Mallory distributor. Is the standard (CW) rotation engine's gear slightly longer? Does the shaft bushing called out in the parts manual actually raise the gear? There is no slop in the gear as I insert it so I assume the bushing is in place. I am guessing I can probably buy the auto version of the gear since this engine is standard."
