I forgot to winterize my 35HP Johnson motor 2 years ago and last year it wouldn't start. This year I cleaned the carburetor, replaced the carb. gaskets with a kit online (didn't replace float though because I wasn't sure how to adjust the new one), replaced gas/oil (added Seafoam), and replaced spark plugs. The engine now starts, but won't idle. I have to keep it revved up a bit and shift into gear or it will die. Tried adjusting the Lean/Rich screw, but it appears to have no effect (didn't hear change in engine speed unless I screwed it all the way in and then it died). I've never worked on a boat motor before (this is my first boat) so I don't know where to go from here. Any suggestions?
