Another note, "drivers" output may vary depending on temperature of the coil itself, as well as the condition of the wires where they are flexing when the stator plate moves through its operation range. So the "driver" may give you intermittent or disturbing readings based on stator position, and temperature. In newer outboards only the trigger.....or timing coil is moving through throttle positions. This eliminates the constant wear on the wires to the stator or "driver coil". A trigger is commonly tested using ohms, but many techs/mechanics make the mistake by not testing the trigger through full operating range of the throttle. So, if the wires are damaged running to your "driver coil"......you can check that with the ohms scale while leaving the multimeter connected while moving the throttle from idle position to full throttle (WOT). I used to run into a similar problem with early GM electronic distributors starting in 1975. The pickup coil is constantly moving based on the vacuum acutated stator plate. In cold weather, the 2 wires going to that donut shaped coil, will crack and eventually deteriorate one conductor after the other, until the module looses its signal from the "trigger" (donut) coil. Then no spark. If outboards are used in very cold conditions, like Northern MN, say in late fall and early winter, the aforementioned scenario can be a critical consideration when diagnosing intermittent spark issues. The same holds true for equipment used in high heat with direct sun. I notice more electrical wiring deterioration in Mercurys not perhaps only due to their black color, but the original composition of the wiring insulation.
Ps. I have a 1976 15 that a customer gave me. One cylinder, he said, drops out after a 5 or 10 minute run. Its still awaiting my diagnosis. May be the same problem you have.....let us know what you find. Thanks, Tim
