I seized this motor up last year. Found a "new" power head online, and put it all back together. I rebuilt carb, rebuilt fuel pump, new plugs, new impeller, and set points. It starts pretty easy, but was spitting out of the fuel recirculation hose in a test tank. (barrel actually) I took it on the water, and adjusted the idle screw and the spitting has seemed to have gone away. It idles fine, runs fine slow, but every so often it makes a clunking noise, mostly at WOT. The odd thing is it does not loose power, it clunks, the motor shakes a bit and continues on. Is this a misfire? Any help would be appreciated. Thanks.
