DangerousDane
I just bought my first boat, 1976 24ft Fiberform Cabin Cruiser OMC 235hp V8 w/ Electric Shift Sterndrive. Its in great shape, and I pretty much stole it for $3100.
She won't go into reverse tho, and the prop trim works but sometimes you have to bang on the clutch with a mallet.
These are the only problems I'm aware of, but I haven't been out on the water yet. I want to fix reverse before I go out on the lake and crash into the marina trying to dock.
I've gathered this much from the forum...
Tomorrow morning I'm going to go test the gears by turning the key on motor off, put in forward and try to turn the prop backwards and vice versa for reverse. Then I'll try to see if its getting the electric signal from the shifter for reverse at the drive and trace it out if need be.
Any thoughts would be appreciated. I found http://www.sterndrive.info/index.html for drawings and parts so maybe I can pull this off if I can figure out whats broken.
