1976 233 mercruiser....Trim ?
ihunt2liv
Hello,
I picked up a 1976 StarCraft Montego a couple months ago. Its in really great shape and is powers by a Mercruiser 233..aka Ford 351..the only issue we are having is the tilt/trim is being unreliable...sometimes works sometimes not...I'm thinking there may be a leak on the bottom of the trim pump. I have pulled up the schematics of said pump and there are 4 o-rings stacked between the valve body and bottom plate. I guess my question is what's your opinion on trying a rebuild or something else? Both solenoids have been replaced and pump runs. Also do they make a complete after market assembly I could just swap out and have the piece of mind?...Any and all thoughts on this boat and setup would be appreciated.
You posted in the outboard section...go to the Mercruiser section and repost. I think you can just replace the entire power trim unit, not cheap.
