Jason_2012
need to know the jet turns for high and low on 1967 omc 120 has rochester carb buddy took boat out nd played with them please help.
Any body??
in or from completly shut
This is what I'm talking aboutSo ok here's more of the problem I had before buddy played with the jets, the Boat starts good I go to take off push the throttle right down and it's only doing 47km/h and that was tested with the iPhone app, the every electronic on the engine has bib replaced with new same with new oil I have bin running two weeks since oil change and it's still golden not black or milky rpm stays right at 2k there's no bak firing going on nothing but yet I put jb reverse it winds out good rpms go up even when it's out of water when hooked too the garden hose it'll wind out like it should intil it's under load then it does it prop has bin changes to new 15x16 which the boats a 16 foot grew 154 I just dont under stand could it be related too the carb also the tinning was set properly I just don't know where too start too sync this problem
just checked fluid levils in power head was empty. could ths cause it?
