1975 OMC Tilt motor
NOTE: If it is still in the boat, you will likely have to take off the outdrive and the transom boot (or bellows) to get access to it. It is held in with two 3/8 inch bolts, take out with a rachet and the leads click apart. The bolts go all the way through the motor, and actually hold the parts of the motor together. Tape the new motor together so that it doesn't fall apart and make a mess.
If you are not sure it is the motor, I can tell you how to check it., As there is an inline fuse that may be blown, or it may be the wiring. You can jump across the large leads on the solenoid which gives 12 volts straight to the tilt motor.
Mine is a 76 190 hp, it may be the same. Or you can punch in your model number in the parts section and go to the intermediate drive section.
Here is a link to this website parts section:
The Arco one is the least expensive and it is very good.
Thank You Neal, my motor is fine,,,, I am looking for a way to slow down the motor so I need to know what kind of Amps. it draws, and the type of construction of it. But thanks again.
So, you want to put a resistor in the line or something? I just put an Arco tilt motor in and don't know about the amps. I asked my friend Grok about the amps and how to slow it down using the Arco as an example and this is what he said:
https://grok.com/ It is free to sign up.
Amps for ARCO Tilt/Trim Motor #6209​
The ARCO tilt/trim motor #6209 is a premium replacement tilt/trim motor designed for BRP-OMC outboards with a 2-wire connection, replacing part numbers BRP-OMC 380361, 382138, 382220, and Sierra 18-6754. Unfortunately, the exact amperage specifications for the ARCO #6209 motor are not explicitly provided in the available sources. However, based on related information about ARCO tilt/trim motors:
  • ARCO motors are rigorously tested, with armatures designed to withstand 50 times the operational voltage (typically 12V for marine applications), suggesting robust electrical performance.
    https://arcomarine.com/products/6209
  • Similar ARCO tilt/trim motors (e.g., #6276, #6223) are tested under multiple load levels to meet or exceed OEM performance, but specific amp ratings are not listed.
    https://defender.com/en_us/arco-oem-replacement-tilt-trim-motor-6276
    https://defender.com/en_us/arco-oem-replacement-tilt-trim-motor-6223
  • As a general reference, marine tilt/trim motors typically draw between 20-60 amps under normal operation, with peak loads potentially higher depending on the system (e.g., single ram, heavy-duty applications). The #6209, being a 12V motor for BRP-OMC outboards, likely operates within this range, but exact figures would depend on the load and application.
For precise amperage, I recommend contacting ARCO Marine directly (via arcomarine.com) or checking the motor’s documentation or label, as this information is often specific to the motor’s design and load conditions.
Methods to Slow Down the ARCO Tilt/Trim Motor #6209​
Slowing down a DC motor like the ARCO #6209 involves reducing its speed while maintaining sufficient torque for operation. Here are several methods to achieve this, with considerations for marine applications:
  1. Pulse Width Modulation (PWM) Controller:
    • How it works: A PWM controller adjusts the motor’s speed by varying the duty cycle of the power supplied, effectively reducing the average voltage while maintaining torque.
    • Implementation: Install a compatible 12V PWM speed controller rated for the motor’s current (likely 20-60 amps, as noted above). Ensure the controller is marine-grade to resist corrosion and moisture.
    • Advantages: Efficient, minimal power loss, and allows precise speed control.
    • Considerations: Ensure proper heat dissipation and waterproofing. Check compatibility with the motor’s 2-wire configuration. Overloading the controller could lead to failure.
  2. Voltage Reduction:
    • How it works: Reducing the input voltage (e.g., from 12V to 9V or lower) using a resistor, voltage regulator, or buck converter will slow the motor.
    • Implementation: A marine-grade buck converter is preferable to resistors, as resistors generate heat and are less efficient. Select a converter capable of handling the motor’s current draw.
    • Advantages: Simple and cost-effective.
    • Considerations: Voltage reduction may reduce torque, potentially affecting the motor’s ability to lift or tilt under load. Ensure the system can still function effectively for your outboard’s requirements.
  3. Rheostat or Variable Resistor:
    • How it works: A rheostat in series with the motor increases resistance, reducing current and slowing the motor.
    • Implementation: Use a high-power rheostat rated for the motor’s current (e.g., 50-100 amps to be safe). Marine-grade components are essential to prevent corrosion.
    • Advantages: Allows adjustable speed control.
    • Considerations: Generates significant heat, reduces efficiency, and may not be practical for high-current applications like tilt/trim motors. Torque may also decrease, impacting performance.
  4. Mechanical Load Adjustment:
    • How it works: Increasing the mechanical load (e.g., adding resistance to the tilt/trim system) can slow the motor’s operation.
    • Implementation: This is not typically recommended for tilt/trim motors, as it involves modifying the hydraulic or mechanical system, which could compromise reliability or safety.
    • Advantages: No electrical modifications needed.
    • Considerations: May strain the motor or system, leading to premature wear or failure. Not a practical solution for most marine applications.
  5. Gearbox or Pulley System (if applicable):
    • How it works: Adding a gearbox or pulley system to reduce the output speed mechanically while maintaining motor torque.
    • Implementation: This would require custom engineering to integrate with the tilt/trim system, as most tilt/trim motors are direct-drive.
    • Advantages: Maintains torque while reducing speed.
    • Considerations: Highly complex and costly for a tilt/trim motor. May not be feasible without significant system redesign.
Recommendations and Cautions​
For further assistance, contact ARCO Marine (arcomarine.com) or a marine service professional to confirm the motor’s amperage and suitability of any speed control method for your specific application. If you’d like, I can search for additional sources or provide guidance on selecting a PWM controller or other components. Let me know!
Once again, thank you lots to read over and think about, my tilt runs down so fast that a light quick touch of the switch and it's down. Also thanks for the offer of help. I will see what develops.
An in-line resistor would probably be easiest. You are only using it for a few seconds. You could just put it on the down line and have 12 volts up.
That's a good thought, I'm having trouble knowing the size resistor to use. I think I would try 10 volts down and thinking the motor may draw 80 amps.
I wonder if a car ballast resistor would do the job?
