Well this was my first encounter with this lower unit.
I changed oil seals and o rings, changed the pinion gear and the bearing carrier with installed revers gear (used identical parts for the gears and bearing carrier) and heli coiled the vent plug. No problem but putting everything back together seems to be a problem. I must be forgetting something.
I reassemble, tighten the cover nut with the spanner wrench then everythning (drive and prop shaft) is seized tight. The shifter is in forward (I did not mess with the shifter cam and is pointing toward the oil plugs)
loosen the cover nut and pull out the bearing carrier a little and it loosens up. But while turning the drive shaft sounds like pinion gear is rubbing on something.
i did did not mess with the shims. The new pinion gears looks like it aligns perfectly with the forward gear.
did I over tighten the cover nut, is that even possible? Did I forget or loose some spacer between the housing and bearing carrier?
