Edin Kordic
Hello,
I am new to the forum and also new to boating so i would like to apologize in advance if i am not explaining my self correctly or if i am not using proper terms for some items.
I have purchased my first boat, it is a 1975 Tri Sonic with a Mercruiser 140.
I got it knowing it needed work, water pump and impeller, head gasket etc.
I got the water pump replaced, then i got the head gasket replaced, it does not overheat any longer and engine sounds good.
The guy that replaced the head gasket and the water pump advised me that i will need a new water shutter but i can do fine without it, i did however order one and it should be here by next week.
I went to a small lake and the boat was running good, went there again and it would have troubles running when in neutral so i would have to shift fast from neutral to drive while idle was high.
The last time i went was today and i ran it at home prior going to the lake and it ran great, i was playing around with the screws on the carburetor and i taught i had fixed it (stupid me)
As soon as i went into water i realized something is very wrong, it would have a really hard time starting, no idle, as soon as i would try to take off it would just kinda bog down and shut off.
One question that i do have is this: there is what looks like a water relieve valve that is on the lower part of the exhaust manifold, when i was on the lake the first time i looked at it and water was coming from it, i didn't think that was supposed to be leaking so i screwed it shut. Could this be why it is having these problems ? Is this something that is supposed to let excess water out ?
Thanks to all in advance for any suggestions !
