tboltmike
I had just dissassembled the c
I had just dissassembled the control box to lubricate and make a wiring repair on the switch on my 1975 115 hp Johnson.
Had everything all layed out and reassembley went well...everything fit except the lower box panel. The throttle mounting knob (the cylindrical piece that locks the cable into the box is displaced about 2 inches back (outside of the box and I can't get it to slide fwd into position.
Not sure if I did something wrong in the assembly of the handle mechanism or if the rod in the throttle cable moved. The throttle handle moves full range and the shift cable works.
Thanks for and advice. Mike
