Ok so I have a 1975 Johnson 85hp with a 13 1/2" 20p prop on a 1984 Stratos 179 Fiberglass bass boat. I pulled the Evinrude 140hp off because of a bad cylinder. So here's a little background of what I know, and the issues I'm having.
Compression check results:
Cylinder 1: 105psi
Cylinder 2: 110psi
Cylinder 3: 100psi
Cylinder 4: 108psi
Compression test done with all plugs removed and fully charged battery.
Spark test results:
All 4 cylinders have a strong Blue spark with a loud "snap" when tested at a 7/16" gap.
Fuel tank has been cleaned thoroughly and all fuel lines replaced, as well as having fresh fuel.
Both carbs have been completely rebuilt. Idle and high speed jets were removed and all pathways cleaned thoroughly and blown out with compressed air.
Motor starts easily and runs good on muffs and in water. But when I try to run at WOT I get a top speed of about 3-5mph and the rpms are definitely not at 5800 rpms. Not sure of actual rpms because I do not have a tach. I'm having an issue with one of the cylinders and cannot figure it out. The motor has an intermittent "miss". Sounds kinda like this when running.....Baaaaaaaaaaaadadaaaaaadaaaaadaaaaaadadadaaaaaaaadaaaaadaaaaaa etc. (I think you get what I'm saying) So what I decided to do was pull the plug wires off one at a time while the motor was running and see which cylinder had the least or no effect when removed. The results of that "test" was that cylinders 1,2,and 4 all made a significant change in the way the motor ran, but cylinder 3 made absolutely no difference at all. The only difference when I remove or connect the spark plug on cylinder 3 is the tone of the exhaust. The way the motor runs isn't improved or worsened when the plug wire is connected or removed. I checked to verify that it is sparking when connected to the plug, and it definitely is. That cylinder has good compression, spark, fuel, and air but doesn't seem to be contributing to the performance of the motor. Also did a decarb on the engine and when spraying Sea foam into the side of the bottom carb for that cylinder there was no change in the way it ran but the motor would bog as I sprayed into the carbs for the other cylinders. I'm lost on this and not sure what to do next.
Also the Port side head is getting too hot. I had it hooked to the muffs and pulled the tubing off both heads that runs to the thermostat/vernatherm housing and had water flowing freely from both heads. Can the vernatherm cause the port side to not flow while allowing the starboard head to flow like it should?
The last issue I noticed was that the motor runs good when trimmed up but as soon as I lower it down and it tilts past being level(actually leans backwards) it instantly runs worse?! Not sure what is causing that. Please, Somebody help me figure this thing out. I'm very mechanically inclined, it's what I do for a living(Industrial Maint. Tech), but I'm fairly new to the world of outboards. Thanks in advance for any and all advice and suggestions.
Cylinder 1: 105psi
Cylinder 2: 110psi
Cylinder 3: 100psi
Cylinder 4: 108psi
Spark test results:
