pablocruz69
I bought this boat about a month ago, the guy started the motor for us and needless to say we bought it. Anyway I took it out on the lake last weekend and tried to start the motor and i got nothing when I turned the key, the choke works, the tilt and trim worked but no starter cranking. I got it home and checked voltage to the solenoid and to the solenoid it had power but after it had nothing. If i bypass the solenoid I can get it to crank (using a wire from power supply to the solenoid and then to the other side of solenoid) I can get the motor cranking and started. Could this be a solenoid issue or a gear position sensor (fwd and reverse)?? Not sure what to think or how to properly diagnose this issue. Thanks in advance for any help or guidance. BTW when I jumped the starter and got the motor running when the throttle was in the neutral position it seemed that the motor was in reverse, but not sure. How do I make sure that the motor is in neutral??
