My 1975 Johnson 50 Engine bogs down at mid to full throttle after a few minutes of running. I have replaced the water pump, plugs and coils. The engine temp is normal (gauge and to touch). Clean fuel and tank was verified. Took it to a shop and they said they put it on a dyno and were able to simulate the same problem. They said the fuel system tests good, compression is 140-145 per cylinder and think it is electrical. They swapped out the stator with a new one with no change. They believe it is the timer base sensor coil and are waiting on the part to ship. My concer is this maybe a carb issue. I don't know much about the dyno test except that it gives hp info. Will the dyno test confirm proper carb function? Any other advise?
