"Hi,
I have a 1975 Johnson 4
"Hi,
I have a 1975 Johnson 4 HP that won't start. The problem appears to be the fuel system. It has all new ignition parts including points (gapped at 0.20), plugs (gapped at 0.30), new coils and condensers. The fuel pump screen is clean and I removed the fuel lines between the fuel pump and carburetor and all are clear. I installed a inline fuel filter between the fuel pump and carburetor so I can watch the fuel flow. I made sure that the flow arrow on filter is pointing toward the carburetor. When I squeeze the primer bulb on the tank fuel line I notice that there is no fuel flowing through the inline filter to the carburetor. I don't know if fuel will only flow through the filter when the engine creates compression through starting or if fuel should already be at the carburetor by just squeezing the primer bulb on tank line. The engine did run as recently as a month ago, but when I had it on the lake it ran pretty well for about 30 minutes and then stalled on me a couple of times and the second time it would not restart. When I started troubleshooting at home I pulled the flywheel and noticed there was some questionable looking ignition parts (cracked coils and burn marks on points) so that was my reason for replacing all ignition parts. In addition to what I told you about the fuel system, I did spray some fuel in the carb. and I can get it to pop like it wants to start but that's as much as she does. The motor has been only freshwater used and is overall in immaculate shape for her age. Any and all help is greatly appreciated."
"Hi,
