I have a '75 Evinrude 6hp. The throttle feels stiff, but it seems to be working. I am only able to start and run the motor if it's on Fast speed according the plastic markers on the throttle. I need to warm the motor up for quite awhile before I am able to shift it into gear because if I bring the throttle down to a low enough level to shift in gear it will usually stall if it isn't good and warm. I wonder if something is off on the throttle or if the setting on the low speed valve is incorrect. What is the correct starting point for the slow speed needle? I have tried gently seating the needle then backing off 1-1/2 turns, but that doesn't seem to correct the issue.
