"The manual I bought gives no
"The manual I bought gives no mention to the electric choke. This model has the two purple wire electric choke not the primer. When the key is first turned to the on position (with the choke off) the choke activtes slightly to about 1/8 closed, is this normal? When you hit the choke switch it closes tightly and evenly, I just question why this initial automatic movement is occuring and does this than open fully when the engine is running? When the key is off the choke is wide open."
