niagara transom
Hi Guys, new here but have always found helpful info on other posts. I'm completely stumped here.
1975 40hp came in wouldn't start. Somebody changed #1 cyl coil. I pulled flywheel, checked points and #1 had no continuity.
Replaced points, then it backfired.
I set up points with ohm meter and flywheel to close between timing marks. The key points towards opposite point dowel about 30 deg btdc and bbdc with timing all the way advanced. Gap looks about 0.050" but 0.020" didn't work on the highest point of cam so I did it with timing marks.
Flywheel is still magnetized. I put it together today, it popped once and then no spark.
I disconnected blue wire at key switch, installed new plugs, pulled ht wires and checked R,went through coils, checked coil grounds. I ohmed both coil wires back to points. I ohmed the single coil under the flywheel. The condensers have continuity 1 way only and measure low on my 20M scale about 1.8 I think.
So whatever I did went from a backfire kicking it out of neutral to completely dead....I didn't see a vacuum cut out but those shouls only kill the lower cylinder any way. The 3 coil mag looks like a charging system, the single coil had very low resistance. New condensers are on order (got wrong parts). Should I be looking into a new mag? Points open and closeso unless I'm WAY off here I should get something. There is no timing mark on bottom of flywheel but there is an E and R. I split the difference between the 2 which was consistent with YT videos I watched.
Thanks for all the great previous posts in the past!
