1975 Evinrude 115 outboard
justinmn
"I just bought a 1975 outboard
"I just bought a 1975 outboard Evinrude 115, I warmed it up, ran water through the muffs. It tried and tried but did not turn over. after that the small crank under the cover fell below the large one and has not come back up? what now? If anyone knows what I'm talking about please let me know what I should do."
"Sometimes all is lost in the
"Sometimes all is lost in the translation. You'll need to be more descriptive/percise in what you're trying to get across to us.
It did not turn over means that the engine's crankshaft etc did not rotate at all. I assume you mean that the engine cranked over via the electric starter but the engine did nor start and run. If so, see the trouble shooting information below.
You'll also need to pinpoint what you're speaking of pertaining to the small crank/large crank.
(Compression & Spark Test)
(J. Reeves)
1st - Regardless of what problem one might encounter, always start with the basic troubleshooting procedure. Check the compression which should be in the range of 100+ psi (somewhat less on the smaller hp engines) and even on all cylinders.
2nd - With the spark plugs removed, rig up some type of spark tester whereas you can set a gap to be jumped. On magneto ignition systems.... and also the Battery Capacitance Ignition system OMC engines from 1968 to 1972, set the gap to 1/4". On the solid state OMC ignition systems from 1973 to the present, set the gap to 7/16". The spark should jump the gap with a strong blue lightning like flame..... a real strong blue snap!
If there was no spark, on engines from 1973 up, disconnect the RED main electrical plug at the engine. Remove the s/plugs. crank the engine via the starter solenoid (jumper bat term to small 3/8" term nut, not the ground nut) and observe spark. If spark is now okay as stated above, the usual cause is a shorted ignition switch.
If the above checks out as it should, and the engine dies out when throttle is applied or won't idle, it is usually due to one or both of two things. The carburetors are fouled, in which case the cure would be to remove, clean, and rebuild them..... or the timer base under the flywheel is sticking which would result in a retarded spark.
To check the timer base for sticking (Engine Not Running), spin the prop to align the shifter dog with forward gear and while doing so, put the engine into forward gear. Now, while watching the timer base, slowly apply throttle clear up to full throttle. The timer base should move smoothly all the way up against the black rubber cap that is atached to the end of the full advance spark setting screw. If the timer base sticks, find out why and correct that problem."
