" I'm working on a 1975 Ev
" I'm working on a 1975 Evenrude 70 HP that has ignition problems. My fishing buddy just purchased it and it ran great the first time out. On the second trip to the river, it quit and wouldn't restart. Cylinders one and two weren't firing and three had a weak spark. He purchased a Clymer Evenrude/Johnson outboard repair manual and I volunteered to try repairs.
A fully charged Eveready deep cycle 115 amp marine/rv battery is in the boat I've installed a new stator ring that produces exactly 175 volts AC and tests at 727 ohms, slightly higher than the given range of 555 - 705 ohms. The three ignition sensor coils tested at 8.3, 9.1 and 9.3 ohms, within the specified 7.5 - 9.5 ohm range.
I still have a weak spark at coil three and don't have spark at coils one and two unless I disconnect coil three at the power pack. One and two then have a strong spark. If I switch the power pack coil lead from coil three to terminals one or two of the power pack, it then throws a strong spark. Any one of the three coils connected to terminal three kills one and two. I've checked the power pack ground and it's good. I've removed the key switch lead at terminal six (which doesn't change the problem) and checked the circuit to the ignition switch (the black/yellow lead is fully grounded only in the key "off" position.)
The repair manual tells how to check the power pack with a spark tester, which I don't have. I need to rely on sparkplugs pulled from the motor and grounded for spark testing and a timing light. Anybody have any ideas how to do check the power pack without a spark tester, or am I overlooking the problem altogether???? "
