Hi all,
I recently inherited a 1975 BW with a 2 stroke 25hp Johnson, after a bit of tinkering, and some new parts (condensers, thermostat, coil, impeller, battery cables, and a kill switch) it is running like a champ.
I do have a couple of questions though.
First the restriction plate for the water pickup only has three tiny holes. While I was testing I had that plate removed, and it was pumping quite a lot more water from the muffs. Is there some reason that it is so restricted? It would be pretty easy to drill a dozen more holes and improve the water flow. Thoughts? If nothing else it would definitely rinse better on the muffs. This is pretty important as I'll be using it almost exclusively in brackish water.
Also my top speed on this setup was about 18mph, that seemed a bit slow, a more comfortable rpm produced 15mph. It did jump right up on plane, but I was expecting something in the 25mph range. I checked the prop and it is an 8x10. I do have a 9.2 x 11 that came with the boat. I assume that will make the whole shot a bit tamer, but should improve the top end. What is the consensus? Will that get me to 25mph? or realistically what should I expect from this boat?
Thanks for the help!
