You never really said what the exact problem was with your low idle but a point set at 0.024" would not have helped it. If you look closely at your throttle system you will see a piece under the flywheel that contacts your roller that controls the throttle butterfly in your carb. As you turn the throttle, this makes the carb open more. What is interesting here is the idle system. When you idle down, the roller actually moves off of the throttle cam, which means your carb is not closing anymore. So why does your idle decrease when you reduce the throttle more? It is because the timing plate is still moving. The timing plate is just under the flywheel and it advances the spark timing at the different RPMs of the motor. As you reduce the throttle twist more, all you are doing is moving the spark timing a little more past top dead center (TDC). This makes the pistons move even slower for the low idle.
Now when your point gaps are adjusted to 0.020", we know it positions everything into perfect timing so the spark fires at TDC at every throttle range except idle, as mentioned above. At idle the timing is moved in the other direction and this is what gives the smooth very low idle. When you increase your point gap, you are also advancing the timing in the other direction. At high RPMs you may not notice the difference from 0.020" to 0.024", but at very low idle you just might. I will point out that it isn't much of a difference and when installing new points, OMC usually recommends a gap of 0.022" anyway, to account for the quick wear that happens to the rub bar on brand new points. My point is that a wider point gap will probably become more noticeable at low idle and a narrower point gap will be noticeable by a reduced top end performance.
The other thing you will want to do is ensure your carb is sync'd properly to this throttle cam. This is done by ensuring that the little arrow indented on the throttle cam is in the center of the carb roller when it "just" hits the throttle cam. This also, is very important to ensure proper spark timing.
